, brad fenn wrote:
> Also something I have run into is what I believe is an issue with the ethanol in
> the fuel. It appears to cause a slight lean run issue with the older cars. I am
> constantly increasing the idle jet size on the old VWs to get a good idle on
> them.And I do lots of work on SU carbs on MGs and Datsun Z cars,not to mention
> have been doing motorcycle carbs lately. But can defiantly say the ethanol is
> really becoming a real problem. We are at E10 right now,and they are talking
> about E15 coming soon.
> From: lyletrudell
> Sent: Mon, March 21, 2011 4:49:13 PM
> Subject: [anzhonda600owners] Re: Carburetor
> Brad good point about the o-ring. On our older motorcycles we would shim the
> needles so it would lift the needle farther out of the seat and richen up the
> mixture.
> Lots of things could be adding to a poor idle.
> It "seems" like the carb is the problem, but.....
> We could come up with a list of things to do.
> I always do the cheapest ones first.
> Lyle
, "lyletrudell" wrote:
> > Hi John & Fred, that narrows your idle problems to fuel delivery.
> > When I got my coupe it also would not idle without a little choke.
> > I still have my Coupe totally apart so I don't know if my carb and engine
> >rebuild has solved the problem.
> > So we all have a lean idle condition.
> > This could also be because the Honda was set to run very lean for emissions and
> >fuel milage. Now that we have crappy fuel and worn leaking carbs the fuel ratio
> >at idle could be very lean.
> > Things that could cause this:
> > * Vacuum leaks, hurt idle worse than high RPM.
> > * Low compression.
> > * Float level too low.
> > * Solenoid not working, or seat damaged.
> > * Carb passages dirty/restricted.
> > * Needles, jets, seats dirty or damaged.
> > * Carb O-rings, seals dried out or damaged (alcohol in fuel).
> > * Vacuum piston sticking or bore damaged.
> > There are other things, the Honda 600 experts can add to this.
> > I would rebuild and clean the carb first.
> > Use Viton O-rings(alcohol in fuel)I do have Viton O-rings left if you need
> >them.
> > craft59@
> > Lyle
, JOHN BURKHIMER wrote:
> > > wanted to pop in on this one. Mine will barely idle, but when i add choke
> >it will- what does that mean?
> > > thanks
> > > john b
> > > --- On Sun, 3/20/11, lyletrudell wrote:
> > > From: lyletrudell
> > > Date: Sunday, March 20, 2011, 9:31 PM
> > > Â
> > > When the engine is warmed, will it idle when the you add some choke?
> > > Lyle
, "fredk1026" wrote:
> > > > I have check the compression and it is 140 psi on both sides. I assume that
> >is acceptable, since the stock compression is 156 psi I hope. Also the internal
> >fuel screen is clear, just a little bent. "Could the coil be giving weak spark?"
