Honda suspension Parts?
Re: Honda suspension Parts?
Post by lyletrudell »
Marshall, in the mid 60's when this engine was being designed, it was very advanced. 45 years later it is pretty common technology, but is still being used. Metric pistons are so common now.
A piston is a pretty complex part, diameter is easy, but wrist pin offset, distance from the top to the pin and dome height are all variables.
I know Mike has found or made pistons that will work in our 600's.
But, off the shelf parts are always a good thing.
Check into it, but I can't believe it will work.
But it would be nice to buy something off the shelf for these cars....just once!
, "Marshall" wrote:
> I'm looking into the possibility of trying Honda Civic ED1 or ED2 engine pistons in the N600. The fact that no mention of this has been commented on as far as I'm aware suggest's it's a No-No.
> Has anybody looked into this ? Marshall.
, "lyletrudell" wrote:
> > Hi Dan, sounds like Honda used very little from the 600 on the Civic.
> > I thought someone found a rear brake hose that works?
> > We need all members helping to look for parts that will replace our worn out stuff. And like I said before, a way to organize our suppliers.
> > To be a good Guru, you have to be all Honda knowing and willing to help the less informed owners beneath them!
> > Lyle
, WoodWizard 33 wrote:
> > > I've already been bitten thanks. The short flexible connector brake hose at the rear is 600 specific - 73 and later have different thread pattern :(
> > > And I try not to bother the gurus with redundant questions without doing my due diligence!Thanks, Dan
> > > --- On Tue, 8/10/10, lyletrudell wrote:
> > > From: lyletrudell
> > > Subject: [anzhonda600owners] Re: Honda suspension Parts?
> > > Date: Tuesday, August 10, 2010, 9:09 PM
> > > I have not looked at the tie rod ends yet.
> > > Come on Bite the bullet! Or just ask one of the Honda Pro's.
> > > I was talking to another member about off road quads as another source.
> > > The 72 coupe uses the same rear wheel cylinder as the Civic.
> > > You could switch over and use coupe brake parts.
> > > Lyle
> > > > Tie rod ends from a 73 Civic look close and are all over ebay - but I've never bit the bullet to find out if they're interchangable. .......and one could surmise the California Honda gurus have already tried !?
> > > > And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....but every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close..... but no cigarÂ
> > > > --- On Mon, 8/9/10, lyletrudell wrote:
> > > > From: lyletrudell
> > > > Subject: [anzhonda600owners] Honda suspension Parts?
> > > > To:
> > > > Date: Monday, August 9, 2010, 10:41 PM
> > > > Â
> > > > I have located lots of parts for my coupe. I want to thank the club members who have helped me over the past months, with parts and information. I am starting to get quite a Honda supplier and friend list together.
> > > > All Honda 600 owners have found are numbers are few, we will never be supported by big auto parts stores! So we need to work together.
> > > > Ball joints & tie rod ends are also something we need to find.
> > > > Nothing worse than a car that doesn't handle good, and this Honda should handle like a Go-Kart when it's rebuilt.
> > > > I am not going to get into the Honda aftermarket parts business.
> > > > Like everyone, I want my coupe rebuilt and some extra parts, but will "try" not to keep all the parts I find to myself.
> > > > I only plan on having one Honda 600 Pop orange coupe!
> > > > Lyle
Dan, check out this site.
http://www.autopartsdeal.com
Volkswagen Karmann Ghia 1974
Did a search from Bill's info.
I will be buying parts from Miles and Mike when I get to that part of the restoration.
Have to support those who tracked down the parts.
I don't care who sells the parts, a fair price is all I ask.
> I could be be wrong about the 73 brake hose working on the 600 - it may have been a 77 that I tried!? So with that, and any potential savings, I've given in to the fact that Miles can supply the rear hose and Mike O can supply the front.
> Shoes from a 73 (B428) !? are exact fit and are readily available but only for dual piston cylinders.
> I've also been through an ATV junkyard to compare brake cylinder pistons in hope of finding a match on an available part, but that too turned out to be close enough only for horseshoes ;)
> As for the KYB GR2 shocks pt# 343143, they're not listed for the 600, or any other Honda.
> But figuring Bill knows they'll work, and further persistence on my part, I was told to look under 70 VW Beetle, 71 Toyota Corolla ....... NO MATCH ! Then was told 73 VW Thing, which I haven't confirmed - but did finally locate the shock searching under 71 Toyota "WAGON" .......and expect delivery any day now.
> Yes it's a group effort, or at least should be, but as is life, "the 10% syndrom"...... and the other 90% "let someone else do it".............
> speedo, choke, tach and throttle cables ?!
> voltage regulators ?!
> coil ?
> Dan
> --- On Wed, 8/11/10, lyletrudell wrote:
> From: lyletrudell
> Date: Wednesday, August 11, 2010, 10:28 PM
> Lyle
> > From: lyletrudell
> > Â
> > Lyle
> > > And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....but every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close..... but no cigarÂÂ
> > > From: lyletrudell
> > > ÂÂ
> > > Lyle
woodwizard
Post by woodwizard »
KYB GR2 shocks, pt.#343143, straight from the KYB website are in hand - or on car rather!
Searching by part number showed no results so I called HQ and finally found them listed for '71 Toyota Corolla Wagon.
Seem a little stiff but have yet to give them a test ride !?
One more Yokohama to mount and I'll be ready for the Labor Day car shows;)
Dan
Thu, 8/12/10, lyletrudell
> From: lyletrudell
> Date: Thursday, August 12, 2010, 9:31 PM
> Lyle
> > Shoes from a 73
> (B428) !? are exact fit and are readily available but� only for dual piston cylinders.
> > I've also been through an ATV junkyard to compare brake cylinder pistons in hope of finding a match on an available part, but that too turned out to be close enough only for horseshoes ;) > > As for the KYB GR2 shocks pt# 343143, they're not listed for the 600, or any other Honda.
> > coil ?
> > Dan
> > From: lyletrudell
> > To be a good Guru, you have to be all Honda knowing and willing to help the less > informed owners beneath them!
> > Lyle
> > > I've already been bitten thanks. The short flexible connector brake hose at the rear is 600 specific - 73 and later have different thread pattern :( > > > And I try not to bother the gurus with redundant questions without doing my due diligence!Thanks, Dan
> > > From: lyletrudell
> > > Lyle
> > > > And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....butÒ�a�� every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close..... but no cigarÒ�a��
> > > > From: lyletrudell
> > > > To:
> > > > �a��
> > > > I
> > > > Lyle
mterrens
Post by mterrens »
FWIW here are the shocks on Amazon.com  - cheap!
> WoodWizard 33
> Friday, August 13, 2010 8:19
> Re: [anzhonda600owners] Re:
> KYB GR2 shocks, pt.#343143, straight from the KYB website are in > hand - or on car rather!
> Searching by part number showed no results so I called HQ and > finally found them listed for '71 Toyota Corolla Wagon.
> One more Yokohama to mount and I'll be ready for the Labor Day car > shows;)
> Dan
> --- On
> > lyletrudell
> > 9:31 PM
> > Volkswagen Karmann
> > Ghia 1974
> > I will be buying
> > parts from Miles and Mike when I get to that part of the > > restoration.
> > I
> > don't care who sells the parts, a fair price is all I > > ask.
> > Lyle
> > > I could
> > be be wrong about the 73 brake hose working on the 600 - it may have > > been a 77 that I tried!? So with that, and any potential savings, I've > > given in to the fact that Miles can supply the rear hose and Mike O > > can supply the front.
> > and are readily available but� only for dual piston > > cylinders.
> > brake cylinder pistons in hope of finding a match on an available > > part, but that too turned out to be close enough only for horseshoes > > ;) > > > As for the KYB GR2 shocks pt# 343143, they're not listed > > for the 600, or any other Honda.
> > they'll work, and further persistence on my part, I was told to look > > under 70 VW Beetle, 71 Toyota Corolla ....... NO MATCH ! Then was told > > 73 VW Thing, which I haven't confirmed - but did finally locate the > > shock searching under 71 Toyota "WAGON" .......and expect delivery any > > day now.
> > as is life, "the 10% syndrom"...... and the other 90% "let someone > > else do it".............
> > cables ?!
> > > coil ?
> > > Dan
> > > --- On Wed,
> > > From: lyletrudell
> > > I thought someone
> > > We need all members
> > helping to look for parts that will replace our worn out stuff. And > > like I said before, a way to organize our suppliers.
> > > To be a
> > good Guru, you have to be all Honda knowing and willing to help the > > less informed owners beneath them!
> > > Lyle
> > In
> > I've already been bitten thanks. The short flexible connector brake > > hose at the rear is 600 specific - 73 and later have different thread > > pattern :( > > > > And I try not to bother the gurus with > > redundant questions without doing my due diligence!Thanks, Dan
> > From: lyletrudell
> > > > Subject:
> > > > To:
> > > I was talking to another member about off road quads as another > > source.
> > > > Lyle
> > > > Tie rod ends from a 73 Civic look close and are all over > > ebay - but I've never bit the bullet to find out if they're > > interchangable. .......and one could surmise the California Honda > > gurus have already tried !?
> > of '73, rear wheel cylinders with dual pistions also looks very > > close!? .....butÒ�a�� every Sedan I've ever had has the single > > piston and the piston itself will NOT interchange with the duallys.
> > .....close..... but no cigar�a��
> > > > --- On Mon, 8/9/10, lyletrudell > > wrote:
> > > > > From:
> > lyletrudell
> > > > > Subject:
> > > > > To:
> > > > > �a��
> > > > > I have
> > located lots of parts for my coupe. I want to thank the club members > > who have helped me over the past months, with parts and information. I > > am starting to get quite a Honda supplier and friend list > > together.
> > have found are numbers are few, we will never be supported by big auto > > parts stores! So we need to work together.
> > > > Ball joints & tie rod ends are also something we need to > > find.
> > good, and this Honda should handle like a Go-Kart when it's > > rebuilt.
> > > > > Like
> > everyone, I want my coupe rebuilt and some extra parts, but will "try" > > not to keep all the parts I find to myself.
> > > > > I only
> > Lyle
Steve nice find.
$27 includes shipping!
That's gotta be the cheapest Honda part yet!
My stock ones are good, but I will order a set for backup.
> Steve
> From: WoodWizard 33
> Sent: Friday, August 13, 2010 8:19 AM
> Subject: Re: [anzhonda600owners] Re: Honda suspension Parts?
> Dan
> --- On Thu, 8/12/10, lyletrudell wrote:
> From: lyletrudell
> Lyle
> > coil ?
> > Â
> > Dan
> > Â
> > From: lyletrudell
> > Â
> > Lyle
> > > From: lyletrudell
> > > ÂÂ
> > > Lyle
> > > > And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....butÃ�'‚ every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close..... but no cigarÃ�'‚ÂÂ
> > > > From: lyletrudell
> > > > To:
> > > > Ã�'‚ÂÂ
> > > > Lyle
brad fenn
Post by brad fenn »
Does anyone have the dimensions of the stock shocks--- extended length and collapsed length? I saw a sedan where he put front shocks off a mustang on it and they were too long. I think that would be the first thing you would need to know when trying to use shocks off something else. And does anybody give those dimensions with their new shocks?
lyletrudell To:
Fri, August 13, 2010 11:16:55 AM Subject:
Steve nice find.
Amazon.com
- cheap!
> Steve
> From: WoodWizard 33
> Dan
> From: lyletrudell
> Lyle
> > Shoes from a 73 (B428) !? are exact fit and are readily available but� only for dual piston cylinders.
> > coil ?
> > Dan
> > From: lyletrudell
> > Lyle
> > > From: lyletrudell
> > > Ò�a�
> > > Lyle
> > > > And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....butÒ�'â��šÒ�a� every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close..... but no cigarÒ�'â��šÒ�a�
> > > > From: lyletrudell
> > > > To:
> > > > Ò�'â��šÒ�a�
> > > > Lyle
Brake shoes and Pads?
I found shoes at auto zone, but no front pads.
Do you have a source besides Civic pads that need to be modified?
> Stock front brake pads are still available, as are rear shoes for the dual piston!
> .....single piston shoes...... not so easy!
> --- On Tue, 8/10/10, paul tate wrote:
> From: paul tate
> Subject: Re: [anzhonda600owners] Honda suspension Parts?
> Date: Tuesday, August 10, 2010, 2:05 PM
> The 73 Civic front brake pads work fine if you don't mind doing a some grinding.
> --- On Tue, 8/10/10, WoodWizard 33 wrote:
> From: WoodWizard 33
> Subject: Re: [anzhonda600owners] Honda suspension Parts? [1 Attachment]
> Date: Tuesday, August 10, 2010, 12:55 PM
> And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....but every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close.. ... but no cigar
> From: lyletrudell
> Lyle
Marshall
Re: Brake shoes and Pads?
Post by Marshall »
Lyle, You should have no problem finding pads...... very common !
> Lyle
> > From: paul tate
> > From: WoodWizard 33
> > From: lyletrudell
> > Lyle
paul tate
Post by paul tate »
There are normally front pads on ebay for $58.
Mon, 8/16/10, Marshall
> From: Marshall
> Subject: [anzhonda600owners] Re: Brake shoes and Pads?
> Date: Monday, August 16, 2010, 1:09 AM
> > Lyle
> > > --- On Tue,
> > > From: paul tate
> > > From: WoodWizard 33
> > > And while on the subject of '73, rear wheel cylinders with dual pistions also looks very close!? .....but� every Sedan I've ever had has the single piston and the piston itself will NOT interchange with the duallys. .....close.. ... but no cigar�
> > > From: lyletrudell
> > > Lyle
