flat towing
Re: flat towing
Hi Brad, I don't know.  I changed the front wheels, freed them and went on down the road.
> brad
> fenn
> Wednesday, June 23, 2010 11:44 PM
> Re: [anzhonda600owners]
> flat towing
> Hey
> Bill, years ago I had a 600 Coupe that had a problem with the front brakes > locking up. It kept building pressure in the front calipers. If I cracked open > the bleeders it would release the pressure and be good for a few more stops > then start locking up again. I had checked pedal free play, replaced both > master cyls. and booster,still had problem. I finally checked the vacuum check > valve and found it full of corrosion, replaced with a new one and problem was > solved. To this day I don't understand why the check valve fixed mine.
> Do you suppose the one you were towing had a problem do to, no vacuum to the > booster.
> "billmyong@earthlin k.net"
> Thu, June 24, 2010 12:54:59
> RE:
> [anzhonda600owners] flat towing
> I have towed a number of 600's on all 4's,
> most were short runs.  One time on a 200 mile run, the brakes locked > up in front and before I noticed the tires were falling off the rims.
> This is not a Honda 600 issue, it is towing with all 4 wheels on the ground > problem.  I use a 2 wheel-haler to keep the two front wheels off the > ground for long drives or transport in a box.
> I am sure there are other
> stories.
> > anzhonda600owners@
> > yahoogroups. com [mailto:anzhonda600 owners@yahoogrou > > ps.com > > ] > > On Behalf Of
> > moyergraffiti@
> > aol.com
> > Wednesday, June 23, 2010 7:23
> > AM
> > Hi all, my dad is preparing to flat tow his Z600 behind his > > motorcoach.  Are there any problems with gear
> > lubrication for long periods of flat towing?  Anybody have > > experience with this? Here are a picture of both the 1948 Spartan > > Motor Coach and the 72 Honda.  We chose the Honda over the Metro > > because of the weight and performance!  Thanks for any input.
