I got it loose and oiled, greased from under the hood.
Now I can't get the cable and speedo gear together. I can't see the gear.
Bad eyes, going for surgery on one of them Friday.
Going in for pre-op
in a little bit so it will be late this afternoon b4 I can get back to it.
Maybe with the break things will go better on next go at it.
Thanks for y'alls help. Don't go away, I may need you again.
> goinhm@...
> Sunday, October 19, 2008 8:02
> Re: [anzhonda600owners] Re:
> Speedometer
> I find it is easier to work on the speedo cable from under the > hood. Where it connects at the reverse gear cover (next to starter > motor), I unscrew it and the cable is accessible. Don't mess with > the 10mm bolt on the side of the cover which holds the speedo gear in > position. Just unscrew the fitting to which the cable is connected (you > may need to use channel lock (or other) pliers). When you insert the > cable back into the speedo gear, there is a key you will see on the > cable and a keyway on the speedo gear.
> good luck,
> > Tom, did you take
> > the speedo cable loose from underneath to grease it.
> > Mine has started to jump back and forth on me. I'm
> > a little feller with little hands and cant get into the back of > > speedo. They must of used midgets to build these little cars.
> > Put a hundred miles on mine yesterday. Had a new exhaust pipe and > > muffler put on and it is louder now than with the old one that was full of > > holes. Sounds like a big motorcycle with the baffles knocked > > out.
> New
> MapQuest Local
> shows what's happening at your destination. Dining,
> Movies, Events, News more.
> Try
> it out!
> Checked by AVG -
> http://www.avg.com
> Version: 8.0.173 / Virus Database: 270.8.1/1732 -
> Release Date: 10/18/2008 6:01 PM
