dragging front brakes
John
Re: dragging front brakes
Post by John »
Thanks again for all the help and tips from everyone.
I ams new to this site and have never been on one before so I am just now reading over all the previous posts and I have not yet rebuilt the booster and I may not get a chance to check any till the weekend but I am hopefull it will be figured out this weekend with everyones tips.
, "feltonminicycle" wrote:
> You should check all the old postings on dragging brakes. You didn't mention rebuilding your brake booster. There's a reaction valve in there and its aluminum in housing aluminum. It gets stuck and your brakes drag.
, "jschmrbr" wrote:
> > I have dragging front brakes after using the brake pedal. I have a resleeved master cylinder, rebuilt rear wheel cylinders, rebuilt calipers, everything flushed with dot 5 fluid and bled, new check valves in the master and all other parts in brake system like new. I still have to wait for the brakes to release after stopping with the brake pedal before I can drive again. Does any one know what is causing the issue?
John
Post by John »
Brake booster was pretty sticky but it is cleaned and reassembled and calipers removed and all parts lubed well and reinstalled. system bled out well, rear brakes adjusted and the brakes work pretty well but I think I need some new cups in the booster to help out sealing it up as the ones in there are 40 years old and a couple had some pitting and were a little hard. The brakes release after about a second or so of using the pedal and it stops well but you have to wait for about a left, right, left before going and its fine but not great yet. I checked the check valve in the booster also it was also good, so any other thoughts?
, "Mark Kuran" wrote:
> Check you have enough clearance between the pushrod and the brake master
> cylinder.
> Mark.
Dr. Whiting
Post by Dr. Whiting »
Booster seal kits for all three boosters available from me to eliminate this kind of problem.
Bruce
John
Post by John »
Bruce,
I am trying to get most figured out before I start the tear down this winter to do body and paint and I will be ordering more from you through the winter and spring to get this great little car back to a daily driver and looking great for my wife next year we hope.
Thanks for all
John
> Bruce
