how to contact K & N
Re: Carb Orings
All;
    Miles is on the mark for Viton, a man made product that will stand up to the Alcohol in the fuel we are forced to use these days.  Most O rings on the shelf are Nitrile and over time will swell and leak.  The Honda GL1000 kits offer the most affordable answer to the carb rebuild.  Some one was offering an accelerator pump, but never did find out if they were any good.  I have been testing a material and process to allow more height in the center post of the pump.  Working units have been in cars for over a year without problems.  But it is still early to see how long it takes for them to leak.   3 carbs, two running, one sitting in fuel (on a carb) to see the affects after it has dryed and then filled again.  The ones Honda made are past their shelf life, meaning that new units are hard and will crack and leak when placed into a carb.   Which is the problem.  If it leaks then it could cause a fire and although this has not been the case with a Honda accelerator pump when it leaks, I don't want this unit to do the same.   But with all the garbage being put into fuel these days testing has to continue.
> Wednesday, March 26, 2008 11:30
> [2cylinderhondas] Carb Orings
> I forgot to mention if you buy individual orings at a bearing/oring
> supplier. Viton is preferred, Nitrile is secondary. Buna will get
> destroyed by the gasoline, they expand and absorb the fuel.
> Zay Speed
> > Hi
> > I
> made a mistake it is not "K & N" thats the air filter people > for > motorcycles and cars my blow it SORRY !
> > it's "K & L" they sell
> after market parts for the motorcycle
> industry Damm it I get those 2 "k's"
> mixed up. They will not sell to
> you direct you would have to go to a
> motorcycle shop that has a "K &
> L " distributor ( most do call and
> ask) or there are out lets
> > through the internet but they try to really
> jack the price up
> > I made the statement that that 600's were designed
> from a 1968
> honda 450 CB motorcycle and that some things were the same > WRONG > statement TO MAKE! I was hit with "You have no clue what you are
> talking about nothing is the same" ok so I will leave it at that I do
> not want to cause any trouble so I will type in some #'s and this is
> on the premise that I do not know what I am talking about OK! and if
> you are crazy enough to listen to it than it is your fault!!!!
> This is K & L dealer book info for 2007 for page # and part # > the best > way to access this with out a problem is find a "After > Market motorcycle > Accessories shop" They will be (or should be) > willing to just hand you the > catalog and pick out what you want to > order.
> > page #219 is your
> "Keihin carb" O-Ring page these will be the what
> you will want to replace
> the idle & main jet, needle & seat
> > o-ring (where the fuel
> comes into the float bowl) the passage plug
> (idle circut) the one for
> accelerator pump passage between
> > carb body and float bowl. I do not
> know which ones are what I just
> have em all and pick them out as I need
> them you will have to use
> some cheap dial calipers to get a close
> measurement to know witch
> pack to order. there small like "004.00X1.00"
> They will be very hard
> and will break when you try to remove them kinda
> sorta measure em
> while on the jet and you will know the size
> close enough, use grease when installing these
> > page 238 Idle and main
> jets (for early CB honda 450 remember I
> about) it is good to change these as
> over time they get bigger from
> molecular friction where (Thats a good
> term) and depending where you live
> like me @
> > 4,500 feet you will want to jet down 1 step on the
> main
> > page 244 tune up kit I am not totally for sure on this one take
> your old points in and match em up if they are not write it will be a
> restocking fee but ask about this first check page 246 for individual
> unit
> > Page 242 secondary coils (Very Good) go to accel home page > for > better info but order through bike shop order "Points twin > type" > > you can go to K & N with the dimensions and they will tell > you the > K & L part # to order for air filter > > oil filter i > think is a "KN-401" not sure measure old one or > clean it and take it > in > > page 151 for cam chain #12-8116 master link #12-0409 but the > K&L > chains are not as good as the "RK" timing chain that part
> # 259826 (description) "BFO5MX 128 cam" and you would have to order > a > master link separate as these are endless chain but you gota cut it > to > install it any way but they will not offer a master link for it so > use the > master link #12-0409 or Honda # 14410-283-000 from the honda > bike shop ask > if they can order "RK timing chain"
> > wow that was a mouth full
> Ya know the front break pads are the
> same as honda motorcycles take one in
> and they will match it up right
> there also you can get caliper rebuild
> kits that match If you have
> the time you can measure and match
> master cylinder rebuild kits but I just like putting a master > cylinder > from a 1993 chevy GEO you have to do a little adapting and > some grinding > but it's cheep get one at the junk yard with fluid > container for $15.00
> > OK SO REMEMBER NONE OF THIS IS CORRECT IT IS ALL LIES THERE IS NO
> CROSS OVER FROM A MOTORCYCLE, I DO NOT KNOWWHAT I AM TALKING ABOUT!!
> IT IS JUST WISH FULL THINKING, IT WILL NEVER WORK
> > GOOD
> LUCK:::::::: ::::::::: ::::::::: ::::::::: ::::::::: ::::::::: ::::::::: ::::
> ::::::::Zay
> J. Speed
> > To: 2cylinderhondas@ ...:
> pecan-man@.. .: Mon, 24 Mar 2008 23:18:40
> +0000Subject:
> [2cylinderhondas] how to contact K & N
> > Zay,I saw your message about carb kit and cam chain for Honda 600
> from K & N I can't find them on internet. I found one for filters is
> all. I also need air filter.Thanks Gerald Knapp
Ray
Re: Carb Orings
Post by Ray »
Went buy the local Honda Motorsports / Car dealership, they sell it all.
Showed the Motorcycle guys the Z's engine and they PROMISED that they
will find a new carb that will work. I am down to the last of my 3
good carbs and it isn't giving a problem (yet), but I drive the Z so
infrequently now I worry about it. I drove it 240 miles on good
friday, the weather was perfect and I had the day off, just drove and
drove, Burned about 5.3 gal of low test. Had guys wanting to trade me
s-10's, rangers and ricer cars for it. It was nice to see the thumbs
up from alot of people - Good day.
I'll let everyone know how the carb quest goes.
They also do rejets at this dealership so I am confident we'll come up
with something.... I wish I had more time.
Thanks.
KC
