Brake pads
Re: Brake pads
Hi Miles;
The website below is the same, but they use one rivet and it's brass.
So it's bonded to the old backing with one rivet in the center to ensure
they wont move in the baking process. Brass will not cause any problems
against the steel disc.
http://www.nationalbrakeservice.com/index.html
-----Original Message-----
[mailto:2cylinderhondas@yahoogroups.com]On Behalf Of Miles
Sent: Sunday, July 29, 2007 11:14 PM
Subject: [2cylinderhondas] Re: Brake pads
I took 100 of them to a local friction company to get relined. They
told me since the original Tokiko pads are formed (the material
protrudes through holes in the steel) that if they just bonded on the
new linings that they could fall off. He told me if I have ones that
are rivetted he could do it no problem.
Can you hook me up with your bonding shop?
, wrote:
> I have taken them to the local brake guy and have them resurfaced.
Cost is
> about the same as new ones. I do it for my 67 Datsun pickup too.
I have
> not had a problem.
]On Behalf Of Miles
> Sent: Saturday, July 28, 2007 11:45 PM
> I found some pads that are a similar size but the holes are too
> large. I stacked them in my milling machine vise and fly cut them
off
> about 1/16" each end to fit in the calipers. They should work
fine,
> but have not tested them yet.
> B&B swears by the Civic cut down pads, but it looks like you would
> have to redrill the holes on one side?
, "kingtrans@"
> > i take early civic pads and use the old 600 pads as a template
and
> saw them to size. be sure to use a dust mask or respriator mask. i
> wet mine with a thick soap solution before i cut them. they work
> great and they're inexpensive. hopes this helps with your brakes.
