Hi Ian;
Your information is incorrect, the retractable seat belt you are
speaking of was a Jan. 1972 innovation to both of the Honda 600's (Sedan
and Coupe) and standard equipment for both models at that time. The lap
and shoulder harness without the retracting mechanism was standard for the
front passenger seats, with only lap belts for the rear. Only the rear
passenger shoulder harness was an option for all Honda 600's. However both
bolt up the same and the shoulder strap can be placed below the rear window
or above it.
Standard equipment is listed on the window sticker as NC or no charge.
Bill Colford
Seat Belts
Re: Seat Belts
The threaded hole is there just as you described.
Tim
In a message dated 5/25/2002 10:51:53 AM Central Daylight Time, iank71@... writes:
Tim
> ah, then you are in good shape. the lap belts should
> have the slot that accepts the optional shouler strap.
> is there a threaded hole over the middle of the back
> window? it may have a plastic cap in it. that's where
> the belt bolts in. do note that this hole is SAE where
> the rest of the car is metric. when you get your
> straps that's where they go. I'll keep my eyes open
> for you. Hope this helps
> Ian
> Fremont, CA
> '70 AN600 sedan
