Re: [anzhonda600owners] My 1972 n 600 turns on by won’t stay
Charles Gould
Post by Charles Gould »
This could be caused by a defective ignition switch, or bad fuel solenoid shut off, or even stale fuel or partially clogged fuel line or carburetor.
I doubt that it is rings if it starts at all.
Chas
RE: [anzhonda600owners] My 1972 n 600 turns on by won't stay
I have a sign in my garage, “You get what you inspect not what you expect” so even though I agree with Charles, make a list and go through it checking off each area as you go.  Remember, the problem is normally the last thing you check.
