shift bushing cushion
gprenticen600
Post by gprenticen600 »
Hello all
Anyone know where I can get a 'shift lever bushing cushion' for sedan ?
item 16 in the parts book for the gearshift.
I don't need the bushings - only the cushion.
Thanks.
Re: shift bushing cushion
Try here
https://www.mcmaster.com/#standard-slee ... s/=1a9vsm9
Light Duty Dry-Running  Flanged Sleeve Bearings
Made of slippery plastics,  these bearings reduce friction without the need for lubrication.
Nylon  bearings are for light loads.
MDS-filled
nylon  bearings create less friction than standard nylon bearings,  making them more wear resistant.
Acetal  bearings are more chemical resistant than nylon and MDS-filled nylon bearings.
Note:
 Dynamic load capacity is the maximum load a bearing can withstand at a given shaft speed.
 If the bearing’s load and speed are below the values listed,  the bearing should work for your application.
For technical drawings and 3-D models, click on a part number.
Note: 2 image(s) originally linked in this post are no longer available (cid:image001.gif@...320, cid:image002.gif@...320).
timk11
Post by timk11 »
I used to make bushings that replaced the cushion, had you asked 2 weeks ago I could had made you some but I am going back to Oregon tomorrow and my machinery is in California.
P. D. Kelly
Post by P. D. Kelly »
Hi found this on our local Craigslist. Seems like a great deal 1972 Honda 600 1972 Honda 600 72 Honda 600 fore sale or trade no title bill of sale for Parts or fix won't start don't know much about it any ...
On Wednesday, November 15, 2017, 9:56:42 PM CST, 'Bill' billmyong@... [anzhonda600owners] wrote:
Try here
MDS-filled
Note:
 If the bearings load and speed are below the values listed,  the bearing should work for your application.
Note: 3 image(s) originally linked in this post are no longer available (ec, cid:EEyZgULwtfKrNHB6YBWP, cid:ABpu9N11TeVPefU0DJJk).
