Transmission mount or rear mount
paul tate
Post by paul tate »
Given that most of the rear mounts are close to 40 years old and the rubber is probably separated or broken like mine.� Has anyone had any success repairing or modifying?� A friend suggested modifying to use donut style mounts similar to the sub frame mounts.� Any thoughts?
Marshall
Re: Transmission mount or rear mount
Post by Marshall »
I was thinking about this very thing just a few hours ago. I am considering looking into pouring cold cast rubber into the contained area.
My centre section is still holding it's position..... just.
It is possible to purchase various shore hardnesses of the cold cast type & it bonds very strongly to prepared steel surfaces.
Marshall
Post by Marshall »
http://www.smooth-on.com/Urethane-Rubbe ... 9l06jsr3d2
John
Post by John »
Hi Paul,
I modified a rear mount using a fast drying, urethane casting product called DEVCON FLEXANE 80, it's available in 1 lb portions in both liquid and putty versions.
I removed the all the loose rubber, cleaned all the metal parts, wrapped some plastic sheeting around the mount then poured in the liquid while propping the bracket with four holes in a centered, vertical position. It is much stiffer than the original mount, but still maintains some flexibility.
It works well for me.
Post by lyletrudell »
Hi John, that is a clever way to fix it.
Where do you get the Devcon?
80 is probably the durometer of the hardened material.
Maybe they make a different hardness?
I was also thinking that it might work on my gear shift linkage in the car. The rubber bushing is hard and cracked.
, "John" wrote:
> Hi Paul,
John Brown
Post by John Brown »
Hi,
I ordered it on-line, I believe it was about $40. DEVCON makes two
different versions. _*FLEXANE 80:* _ Shore A, 87 durometer and _*FLEXANE
94:*_ Shore A, 97 durometer.
I did a quick search on the web and came up with this source, but I am
sure I've seen it in hardware stores.
Here's a link for this product (the first one I found)
http://www.markingpendepot.com/browsepr ... iquid.html
Hope this helps,
John
> , "John"
> > Hi Paul,
> the rubber is probably separated or broken like mine. Has anyone had
> any success repairing or modifying? A friend suggested modifying to
> use donut style mounts similar to the sub frame mounts. Any thoughts?
blake neilson
Post by blake neilson »
I am not dealing with this question now but I know I will need to at some point.  I imagined I would replace the original rubber with windshield urethane.  Pretty tough stuff but maybe too stiff when set.
Thu, 5/27/10, Marshall
> From: Marshall
> Subject: [anzhonda600owners] Re: Transmission mount or rear mount > To: anzhonda600owners@yahoogroups.com > Date: Thursday, May 27, 2010, 1:49 PM
> , paul tate wrote:
> > Given that most of the rear mounts are close to 40 years old and the rubber is probably separated or broken like mine.  Has anyone had any success repairing or modifying?  A friend suggested modifying to use donut style mounts similar to the sub frame mounts.  Any thoughts?
Marshall
Post by Marshall »
Hi Blake, Devcon products are expensive in UK. Windshield urethane may be worth considering as an economic alternative, although Devcon 80 & 94 are made for such a job !
> --- On Thu, 5/27/10, Marshall wrote:
> From: Marshall
paul tate
Post by paul tate »
Thanks for the info.  Sounds like a good solutioin.
-- On Fri, 5/28/10, lyletrudell wrote:
> From: lyletrudell
> Subject: [anzhonda600owners] Re: Transmission mount or rear mount > To: anzhonda600owners@yahoogroups.com > Date: Friday, May 28, 2010, 6:10 PM
> , "John" wrote:
> > Hi Paul,
> > I removed the all the loose rubber, cleaned all the metal parts, wrapped some plastic sheeting around the mount then poured in the liquid while propping the bracket with four holes > in a centered, vertical position. It is much stiffer than the original mount, but still maintains some flexibility.
paul tate
Post by paul tate »
Hi Blake,
I happen to have an extra tube of urethane laying around from the last project.  I might give it a try.
Paul
Fri, 5/28/10, blake neilson
Subject: Re: [anzhonda600owners] Re: Transmission mount or rear mount To: anzhonda600owners@yahoogroups.com Date: Friday, May 28, 2010, 9:17 PM
> From: Marshall
> Subject: [anzhonda600owners] Re: Transmission mount or rear mount > To: anzhonda600owners@ yahoogroups. com > Date: Thursday, May 27, 2010, 1:49 PM
> My centre section is still holding it's position.... . just.
