Paint
kevin.gailey
Paint
Is there any aerosol auto can paint that is close to the pop Orange on the Coupes? Need to do some touch ups.
Thanks again, Kevin Gailey
Re: Paint
I use Tower Paint, who can produce the paint from the pop orange code and provide spray cans or quart cans. I think a 16oz spray can is about $18. Here is the email I sent them in 2003- ask for enamel paint. Email is info@...
. The paint matches perfectly, however the paint on my Coupe is only 10 years old or so. In any event, it should be fine.
I would like to order two (2) spray cans and one (1) touchup bottle of Pop Orange, which is Dupont stock # 37617, Honda Color code YR-12, for my 1971 Honda 600 Coupe.
FYI, here are the color codes http://www.honda600coupe.com/Honda_600_ ... _codes.pdf
> kevin.gailey
> Tuesday, June 09, 2009 1:58
> [anzhonda600owners] Paint
> Is there any aerosol auto can paint that is close to the pop Orange on the > Coupes? Need to do some touch ups.
> Thanks again, Kevin
> Gailey
> Checked by AVG -
> www.avg.com
> Version: 8.5.339 / Virus Database: 270.12.59/2165 - Release > Date: 06/09/09 05:53:00
Re: Paint
I use Tower Paint, who can produce the paint from the pop orange code and provide spray cans. I think a 16oz spray can is about $18. Email is info@...
. The phone number there is 1-XXX-XXX-XXXX. The paint matches perfectly, however the paint on my Coupe is only 10 years old or so. In any event, it should be fine.
Here is the email I sent them in 2003 - ask for enamel paint:
> kevin.gailey
> Thanks again, Kevin
> Gailey
> Checked by AVG -
> www.avg.com
Re: Paint
Getting close to paint time on my 1972 Pop Orange coupe.
I want to use a base coat clear coat paint.
The paint shop says they cant cross referance the codes.
Honda YR12, Dupont 37617, Rinshed-Mason 7391
Anyone painted with the new paint?
Any new codes?
Any new codes?
, Steven Michelsen wrote:
> I use Tower Paint, who can produce the paint from the pop orange code and provide spray cans. I think a 16oz spray can is about $18. Email is info@... . The phone number there is 1-XXX-XXX-XXXX. The paint matches perfectly, however the paint on my Coupe is only 10 years old or so. In any event, it should be fine.
> Steve
> From: kevin.gailey
> Sent: Tuesday, June 09, 2009 1:58 PM
> Subject: [anzhonda600owners] Paint
> Checked by AVG - www.avg.com
> Version: 8.5.339 / Virus Database: 270.12.59/2165 - Release Date: 06/09/09 05:53:00
Re: Paint
Hi Lyle;
Miles is right, the body shop will make up the paint to match a panel from an area the sun has not gotten to. Base coat clear coat is the performance package for HVLP systems in use today. And, very few are using solvent based paint systems anymore. The nice thing about the clear coat is that you are cleaning clear and not the color. Much easier to take care of, and the water based paint stays in the can for a much longer time. If the shop is looking for a base color to start with, see if they have the color mix for Omaha Orange and tint a shade lighter to match. Then have them make enough to paint your car, fill a couple of spray cans and a bottle of touch up.
> Saturday, July 09, 2011 9:49 PM
> [anzhonda600owners] Re:
> Paint
> I want to use a
> the codes.
> Anyone painted
> with the new paint?
> Any new codes?
> Thanks
> > I use Tower Paint,
> who can produce the paint from the pop orange code and provide spray cans. I > think a 16oz spray can is about $18. Email is info@... . The phone number > there is 1-XXX-XXX-XXXX. The paint matches perfectly, however the paint on my > Coupe is only 10 years old or so. In any event, it should be fine.
> and one (1) touchup bottle of Pop Orange, which is Dupont stock # 37617, Honda > Color code YR-12, for my 1971 Honda 600 Coupe.
> > Steve
> From: kevin.gailey
> > Thanks again, Kevin
> Gailey
> > Checked by
> AVG - www.avg.com
Re: Paint
Hi Bill, I stripped and primed all my removable painted parts.
I might get a paint chip book and see what matches my interior panels.
I am painting the car inside and out so matching is not important, but I want it close to original.
, wrote:
> Hi Lyle;
> up.
]On Behalf Of Lyle
> Sent: Saturday, July 09, 2011 9:49 PM
> Subject: [anzhonda600owners] Re: Paint
> Any new codes?
> Thanks
, Steven Michelsen
> info@ . The phone number there is 1-XXX-XXX-XXXX. The paint matches
> > Steve
> > From: kevin.gailey
> 06/09/09 05:53:00
Re: Paint
I finally found a paint shop that will match my Pop Orange color, Honda YR12.
FinishMaster is the shop and they used a Limco paint.
I will be using a basecoat/clearcoat type paint. I have used this on all my classic cars. The color matches my inside panels perfect.
> Thanks
, wrote:
> > Hi Lyle;
> > up.
> > [mailto:
]On Behalf Of Lyle
> > Any new codes?
> > Thanks
> > Lyle
, Steven Michelsen
> > > Steve
> > > From: kevin.gailey
> > 06/09/09 05:53:00
laurie_randall
Paint
My paint color is POPO green code G 20 for my 1972 Honda az600. RM paint.I can't seem to find a place that can supply it. Want some on hand and for touch ups if i need them.Thanx,Laurie
Re: Paint
try here, i read an earlier post about someone getting orange from them. I just emailed them like 3-4 days go because i need a rattle can of green as well but never heard back hopefully they are still making it.
keep us posted as will i. i need a can ASAP
http://www.apstowerpaint.com/
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
On Jul 15, 2012, at 11:53 PM,
laurie_randall@...
Re: Paint
I just got an email back from the paint company I sent the link to. They can make the popo green in enamel, lacquer or base coat. Just call them they said
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
phone
fax
mobile
laurie_randall@...
