Another article is up for downloading - See the bottom of my page http://www.honda600coupe.com/Manuals,_b ... ments.html for Motor Trend's comparison of the Honda 600 Sedan and the Fiat 850. 5MB file. Download, print, enjoy.
article for downloading
Rear Shocks
A while back the question was asked about shocks for the Coupe or Sedan - the KYB GR2 shock Part no. 343143 for $30.00 each is a bolt on replacement.
A bit stiff, but it is the correct length and width.
Re: Rear Shocks
--- In anzhonda600owners@yahoogroups.com, wrote:
part of shock off that protects chrome.I have taken three front
struts apart the third one had complete seal or teflon ring so went
to a hydrolic/hose distributer told them it was for a 1200lbs car and
they messured grove on chrome shaft and bore i got four teflon rings
they are not split rings he said run hot water on ring and pull over
shaft cool down with cold water too get shape back if it don't look
right i will split it as the third strut had a split ring other two
struts the seal was too far gone tell what it was. also got pro honda
suspension fluid 10w i have not done this yet maybe in a couple of
weeks
thanks for part# also an e-mail about vw shocks i had too cut the top> A while back the question was asked about shocks for the Coupe or Sedan -
weeks
Re: Rear Shocks
Hi Bill,
As you may recall the rear end of my Coupe sits about 2 inches higher than it ought to. Is it possible that the shocks are the issue? How can I tell if I have original or aftermarket shocks?
Thanks, Steve
Thanks, Steve
> billmyong@...
> Honda group -
> 2cylinderhondas
> Sunday, January 07, 2007 5:17
> [anzhonda600owners] Rear
> Shocks
> A
> while back the question was asked about shocks for the Coupe or Sedan - the > KYB GR2 shock Part no. 343143 for $30.00 each is a bolt on > replacement. A bit stiff, but it is the correct length and > width.
> Internal Virus Database is out-of-date.
> Checked by AVG Free
> Edition.
> Version: 7.5.432 / Virus Database: 268.15.29/607 - Release Date:
> 12/28/2006 12:31 PM
Re: Rear Shocks
--- In anzhonda600owners@yahoogroups.com, Steven Michelsen
on replacement. A bit stiff, but it is the correct length and
width.
leaf spring that the upper spring just hits also 27.5 inchs from
floor to top of left&right side marker lite.if you think to high you
can loosen the four bolts at rear of leaf spring add some weight too
car then retorqe four bolts remove weight recheck left & right side
for hight. factory shock is 10.5 colapsed to 17 inches extended top
of shock houseing not top of the stud. you may have a air charged
shock or the four bolts where retorqed when car body was on jacks and
should have been on axle
higher than it ought to. Is it possible that the shocks are the> Hi Bill,
Sedan - the KYB GR2 shock Part no. 343143 for $30.00 each is a bolt> Thanks,
> Steve
> From: billmyong@...
; Honda group - 2cylinderhondas
> Sent: Sunday, January 07, 2007 5:17 AM
> Subject: [anzhonda600owners] Rear Shocks
width.
sedan&coupe also on my coupe on rear there is a rubber stop on bottom> Bill
> look on side of shock for part # 52610-601-024 shock japan for
> Checked by AVG Free Edition.
> Version: 7.5.432 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 12:31 PM
