Okay just an FYI;
With a bit of searching I came across a brake manufacturer through a
Hemmings Motor News add. Called "Brake & Equipment Warehouse" at
INFO@... attention Rob, or at their website "www.brakeplace.com"
or call 1-XXX-XXX-XXXX EXT.648. Rob said he could provide the Honda 600
brake lines and fittings. He said they also sleeve wheel and with stainless
steel at $50.00 a cylinder and as for the 10 x 1.25mm line end nuts he can
provide them for $1.50 each. They have the 3/16" line from 10 inches to 50
inch lines and longer coils with the ends fitted. So, if your looking for
new hard lines, Hoses, cylinders resleeved and rebuilt, they seem to have
the capability.
600 brake lines threads
Harry Lineback
Re: 600 brake lines threads
bill
YOU are amazing !!!!!!!!
your investigative work is always appreciated.
harry
--- Bill Colford wrote:
Harry Lineback
harry
=== message truncated ===> Okay just an FYI;
> Warehouse" at
INFO@...
> the capability.
]On Behalf Of
> Miles Chappell
> Sent: Monday, October 10, 2005 9:54 PM
> Subject: [2cylinderhondas] Re: 600 brake lines
> threads
> Brake Lines & Fittings Defined:
> Wheel cylinders (rears) on the USA sold Honda 600
> Sedan & Coupe:
> The Hard lines and flex lines have 10 x 1.25 thread
> pitch.
> The Bleeders are 8 x 1.25 thread pitch
> The Calipers are 10 x 1.25 thread pitch on the Banjo
> fittings
> The Bleeders are 10 x 1.0 thread pitch
> Brake Master cylinder hard lines are 10 x 1.25mm
> Brake Booster in & out 10 x 1.25 (early sedan bendix
> boosters differ)
> Brake booster low pressure switches 1/8 BSP not NPT
> thread pitch
> Civic & most other later Honda's flare nuts are 10 x
> 1.0mm thread
> pitch and unless you use Civic wheel cylinder
> forcing the flare nuts
> in is not recommended.
> You can cut the Honda 600 or S600/S800 flare nuts
> off the steel
> brake lines then install them onto your new 3/16"
> steel lines.
> Finding the flare nuts in the Honda 600 pitch is
> difficult but I
> hear someone in Japan made new ones for the S600
> people.
> I bought a Double Flaring tool many years ago from
> Sears and
> recently used it to make hard lines for my Honda
> motorcycle using
> some re-zinc flare nuts and new 3/16" line.
, "Jonathan
> Mistchenko and
> Sarah Reeves" wrote:
> > I am replacing the longest line to the back
> because it is plugged
> with dried brake fluid, so I am threading the lines
> into the MC and
> the porportioning valve near the rear axle. I guess
> a few turns is
> not enough to know if the threads are truly
> compatible. I thought I
> grabbed lines from a box that said "metric", but I
> just looked and
> the label on the actual lines says nothing about the
> threading. I
> will go to NAPA tomorrow and make sure I get the
> right ones. I only
> tightened the MC end finger tight (and got a nice
> brake fluid puddle
> on my garage floor overnight), but I did use a
> wrench on the
> porportioning valve so I may need to steal the one
> from my other 600.
> > Thanks again for the help. I plan to get to the
> DMV this week and
> register this car so I can start driving it instead
> of just lying
> under it.
> > Jon
> > From: Bill Colford
> > Sent: Monday, October 10, 2005 3:25 AM
> > Subject: RE: [2cylinderhondas] an 600 brake
> lines
> > Hi Jon Mistchenko;
> > I am not clear on what your threading your
> new brake line
> into. But, as already stated, all threads are
> metric on the Honda.
> And as Larry said, don't try and tighten it as there
> will be (Hell)
> to pay trying to thread in a metric end later.
> > The Hex end of the fitting is for a 10mm wrench,
> but the thread
> diameter is 8mm, 1.0 thread pitch if memory serves
> me correctly as I
> don't have one sitting with me as I answer this
> e-mail at 3 am. You
> should have the one you removed to use as a
> comparing item when you
> go to the parts store. But if you told the parts guy
> at the store
> what it was for when you purchased the first one,
> and he sold you a
> SAE then I'd look for another parts guy.
]On Behalf Of
> Larry Cooley
> > Sent: Sunday, October 09, 2005 10:02 PM
> > Subject: Re: [2cylinderhondas] an 600 brake
> lines
> > The "flare nuts" on the brake lines are a 10
> mm thread... the
> brake lines with the proper nuts can be purchased
> at Bap Geon
> and Napa auto parts outlets in lengths that vary in
> 10 inch
> increments!!
> > I hope you did not try to tighten the 3/16
> line...the brass
> fittings are kind of soft!!
> > Back on the street soon?!?!
> > C'Ya
> > Larry Cooley
> > Wayne Linschied wrote:
> > Could they be Metric? Most Hondas are.
> > Wayne
> > From: "Jonathan Mistchenko and Sarah Reeves"
> > To: > Sent: Sunday, October 09, 2005 6:00 PM
> > Subject: [2cylinderhondas] an 600 brake
> lines
> > > I am replacing the long brake line to the
> back of the car
> and the 3/16"
> > > lines I bought don't seem to be the right
> thread
> pitch...they screw
> > together
> > > for a few rotations and then get very
> tight
Harry Lineback
