well going to DMV this week to get plates & reg for the N600....
one thing, the throttle cable is sorta sticky...
if you rev it @ the carb, it revs fine, drops off quickly...
but while inside with the pedal,
it revs up & very slowly goes back to idle...
is there a fix for the sticky cable?
or should i just try to find a new one?
thanks for the advise!
~Aaron
sticky throttle cable....
Re: sticky throttle cable....
Well, maybe not specifically to the 600, I've had luck with removing said cable, drenching the internals with tons of WD40 by spraying into both ends of the cable, and working the cable in and out of the sleeve. You should be able to feel the cable loosen up.... Reattach the cable, then check for excessive slack. Should be good, but I bet somebody else knows a better Honda 600 specific fix for this.
> Pawzi
> [mailto:dbl_a11@...]
> Wednesday, February 26, 2003 3:44 PM
> [anzhonda600owners]
> sorta sticky...
> quickly...
> or should i
> thanks for the
> advise!
> ~Aaron
> To
> unsubscribe from this group, send an email
> to:
> anzhonda600owners-unsubscribe@yahoogroups.com
> Your
> Yahoo! Terms of Service
What I did on mine was take a zip lock bag and cut one of the bottom corners out of it. Then stick the cable through this hole and seal it up with a rubber band. Hang the bag from your hood and put some oil in it, and let it set a few hours. Then work the accelarator pedal up and down a few times. Remove bag and wipe off excess oil, and reattach. Should work like new then.
Greg
Reggie wrote:
Greg
> > Pawzi [mailto:dbl_a11@...]
> > [anzhonda600owners] sticky throttle cable....
> > ~Aaron
> > Your use of Yahoo! Groups is subject to the
Do you Yahoo!?
Yahoo! Tax Center
- forms, calculators, tips, and more
Hi Aaron;
Pick up some cable lubricant from a motor cycle shop. Disconnect it
from the carb and work it into the cable by putting some on the cable and
pulling it back into the housing. This should free it up, if there are
kinks, that is another problem.
Replacing it is better than trying to fix it.
