Brake problem
hedoshedo2
Re: Brake problem
yes I've had it completely apart I don't think that the problem
Miles Chappell
Re: Brake problem
The switches on the Master are not brake light switches. Brake light switch is on the pedal.
You could disconnect 1 switch and road test for low pressure failure, then test the opposite switch.
For me I have always bled the front brakes first then the single rear because the master has 2 separate
systems. For a system like the s600/800 I would agree with furthest from mcyl then opposite rear then
front farthest then closest. The front fluid has to pass the master, the booster and the calipers - just try it.
TYE M KNOERNSHCILD
Re: Brake problem
Some one know of how to get O-rings and cup seals for brake booster for coup or sedan Tye in Okla
