ball joints needed
eric.geiger
ball joints needed
Post by eric.geiger »
i know this is a long shot but does anyone have 1 or 2 lower control arm ball joints they want to sell.
or a source for reproduction?
Thanks!
Mark Kuran
Re: ball joints needed
Post by Mark Kuran »
Anyone ever tried this http://www.nutechpolymer.com/ Here in Australia, I have used their services with excellent results.
Mark.
amareto23
Post by amareto23 »
i've used early civic joints. hope this helps
53 Year Old Mom Looks 33
The Stunning Results of Her Wrinkle Trick Has Botox Doctors Worried
http://thirdpartyoffers.juno.com/TGL314 ... affst01duc
sirjerryj
Post by sirjerryj »
Ditto. I'm looking for the same. No luck so far though.
Jerry
> Thanks!
Kevin Lister
Post by Kevin Lister »
Mike,
So, you have successfully used early Civic ball-joints in a 600?
How many miles did you put on them after installing?
Any probelms?
kev
michael w king To:
Friday, August 10, 2012 3:40 AM Subject:
Re: [2cylinderhondas] ball joints needed
53 Year Old Mom Looks 33 The Stunning Results of Her Wrinkle Trick Has Botox Doctors Worried http://thirdpartyoffers.juno.com/TGL314 ... affst01duc
amareto23
Post by amareto23 »
their still on it after 8 years with no problems. i did have to modify
the control arm or joint slightly. the eye-clip is different where it
sits. seems like that it wasn't hard to do at all. i had a 74' civvic
that i parted out and used them on my 71' 600 coupe. ,Michael
NetZero now offers 4G mobile broadband. Sign up now.
http://www.netzero.net/?refcd=NZINTISP0512T4GOUT1
Post by Eric Geiger »
do you know how it needed to be modified?   is it something that i can do in my home garage or shop? or something more extensive that you need a fabricator for?
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
amareto23
Post by amareto23 »
i can't remember all that it took to do it. seems a die grinder and a 3"
cut off wheel to give it room for the later clip is all. one clips on
top-side and the other clips on the bottom-side [seems to be the best
recollection i have]. But like i said it's been alot of water under the
bridge--if you know what i mean. Should'nt be much to obtain a civvic
joint and lay them side by side to see for yourself. that's what i did
and bada bing. ,Michael
Mom Lazy Way to Look Young
Doctor Reveals Way to Look Significantly Younger in 17 Seconds
http://thirdpartyoffers.juno.com/TGL314 ... 1e0st02duc
