Head Gasket
jpro8071
Bonneville Honda (was Re: Head Gasket)
Post by jpro8071 »
For production you do have to stay stock in the valve configuration, so only 2 valves for the Z/N 600s. (You can change the port angle if you've got the time and $$.)
And we did offset the bore (and re-sleeve) to comfortably get the 700cc size. 750 can be done, but I'd rather spend the whole week racing than melt down the first day after spending a year preparing.
I've talked more with my sponsor about building cranks. He's gotten a bit more excited by the idea, which is why I posted the poll on after-market cranks. (My goal would be to come up with something so I can get my 750cc motor, and everyone else can get a new crank/piston setup that gets them a little more displacement and power along with the comfort of knowing it's new and should last a long time . . . )
, "lyletrudell" wrote:
> Wow, that is some open rules.
> The "Stock block" really opens it up for a 4 valve head design!
> Maybe Re-sleeve the block, offset wider so you can bore it out to 750.
> So many high tech engines out today to take parts from.
> I would love to go see the cars run.
> The worlds fastest Indian was a cool movie!
, "jpro8071" wrote:
> > The class is actually limited to 750cc, and since newer production cars can run EFI, they allow older cars to. (There is a "classic" production class for larger displacement - carbs or mechanical fuel injection only.)
> > My sponsor was only comfortable pushing things to 700cc. I'm pretty sure that 750cc has been done on a stock stroke, but it makes for very thin cylinder walls. There are also some issues with space for sealing the head gasket.
> > The two main parts of the production class is having the "stock" block, and the body having the stock configuration.
> > Bonneville is quite an experience. You can really get up close and "look under the hood" of most of the cars. People are really friendly, like to answer questions. If anyone out there plans on running a vehicle, I highly advise attending once to spectate. Get a feel for the process, environment, rules, etc..
> > And of course if anyone plans on going out to spectate, let me know. If I'm out there I'm happy to share my pits and perhaps show you around.
> > > Nice job on the car. Like the ignition system and fuel injection.
> > > Are you in a stock under 700cc class? I didn't think you could modify the car that much without going into the unlimited class.
> > > Bonneville would be so cool to go watch or run.
> > > Lyle
, "jpro8071" wrote:
> > > > You can read more here:
http://jdmtown.garagecity.com/600hondaavenue/97//
> > > > I'm pretty sure they were water cut, but I could be wrong.
> > > > --- In
> > > > > jpro, your Bonneville Honda sounds interesting, where do I go to see what you have done? Pictures/info.
> > > > > Good idea with the copper gasket.
> > > > > Do you get them laser cut or water jet?
> > > > > A cheap way for a batch run.
> > > > > Thanks
> > > > > Lyle
> > > > > --- In
, "jpro8071" wrote:
> > > > > > I just read my post and realized it wasn't that clear - I'm talking about head gaskets made from one piece of copper with no other gasket material involved.
> > > > > > --- In
, "jpro8071" wrote:
> > > > > > > Since no water is involved, all copper head gaskets work great. We've been using them on the Bonneville Honda for years with great success. PM me if you have interest in getting one and I'll see what sort of bulk deal I can arrange.
Post by lyletrudell »
Yes, the crank is a weak point for sure, the new crank should be a good way to save some engines.
The oil pump system also is a weak link, have you done anything with the pump?
> > Lyle
> > > > Lyle
> > > > --- In
> > > > > --- In
> > > > > > Thanks
> > > > > > Lyle
> > > > > > --- In
> > > > > > > --- In
CHEYENNE FLETCHER
Re: Bonneville Honda (was Re: Head Gasket)
Post by CHEYENNE FLETCHER »
I was wondering. If you stroke the motor do you have to relieve the crankcase and jugs?
> jpro8071
> Wednesday, June 16, 2010 1:35
> [2cylinderhondas] Bonneville
> For production you do have to stay stock in the valve configuration, so > only 2 valves for the Z/N 600s. (You can change the port angle if you've got > the time and $$.) > And we did offset the bore (and re-sleeve) to > comfortably get the 700cc size. 750 can be done, but I'd rather spend the > whole week racing than melt down the first day after spending a year > preparing.
> I've talked more with my sponsor about building cranks. He's > gotten a bit more excited by the idea, which is why I posted the poll on > after-market cranks. (My goal would be to come up with something so I can get > my 750cc motor, and everyone else can get a new crank/piston setup that gets > them a little more displacement and power along with the comfort of knowing > it's new and should last a long time . . . ) > --- In > 2cylinderhondas@yahoogroups.com > , > "lyletrudell" wrote:
> > Wow, that is some
> open rules.
> design!
> > Maybe Re-sleeve the block, offset wider so you can bore it out > to 750.
> from.
> > The worlds fastest
> > Lyle
> "jpro8071" wrote:
> > > The class is
> actually limited to 750cc, and since newer production cars can run EFI, they > allow older cars to. (There is a "classic" production class for larger > displacement - carbs or mechanical fuel injection only.)
> > My sponsor was only comfortable pushing things to 700cc. I'm pretty sure > that 750cc has been done on a stock stroke, but it makes for very thin > cylinder walls. There are also some issues with space for sealing the head > gasket.
> is having the "stock" block, and the body having the stock > configuration.
> People are really friendly, like to answer questions. If anyone out there > plans on running a vehicle, I highly advise attending once to spectate. Get a > feel for the process, environment, rules, etc..
> > > And
> of course if anyone plans on going out to spectate, let me know. If I'm out > there I'm happy to share my pits and perhaps show you around.
> > Are you in a stock under 700cc class? I didn't think you could modify the > car that much without going into the unlimited class.
> > > > Lyle
> > > > --- In
> > > > > --- In
> > > > > jpro, your Bonneville Honda sounds interesting, where do I > go to see what you have done? Pictures/info.
> > > > > > Good
> cut or water jet?
> run.
> > > > > > Thanks
> > > > > > --- In
> "jpro8071" wrote:
> > > > > > I just read my post and realized it wasn't that clear > - I'm talking about head gaskets made from one piece of copper with no other > gasket material involved.
> > > > --- In
> copper head gaskets work great. We've been using them on the Bonneville Honda > for years with great success. PM me if you have interest in getting one and > I'll see what sort of bulk deal I can arrange.
jpro8071
Post by jpro8071 »
From what I can tell - no. The connecting rods sit fairly deep inside the plates.
(But then only time will tell . . . )
> From: jpro8071
Sent: Wednesday, June 16, 2010 1:35 PM
> Subject: [2cylinderhondas] Bonneville Honda (was Re: Head Gasket)
> > Lyle
> > > > Lyle
> > > > --- In
http://jdmtown.garagecity.com/600hondaavenue/97// > > > > I'm pretty sure they were water cut, but I could be wrong.
> > > > > --- In
> > > > > > Thanks
> > > > > > Lyle
> > > > > > --- In
> > > > > > > --- In
jpro8071
Post by jpro8071 »
We run Bill's oil cooler. Plus the oil to feed the top end (cam) (and one of the mains via gravity) is fed from a feed off of the oil cooler. So the oil that feeds the top basically does NOT go up cylinders, which helps to keep it cooler.
Plus we ran Mile's remanufactured oil pump.
> > > Lyle
> > > > --- In
> > > > > Lyle
> > > > > --- In
> > > > > > --- In
> > > > > > > Thanks
> > > > > > > Lyle
> > > > > > > --- In
> > > > > > > > --- In
I have my oil pump out. How about some more detail on the modified oil path from the oil cooler. The oil cooler to me is the best addition to any air cooled engine. I am not racing but better oiling is always a good thing.
Craft59@...
> > Lyle
> > > > Lyle
> > > > --- In
> > > > > --- In
> > > > > > Lyle
> > > > > > --- In
> > > > > > > --- In
> > > > > > > > Thanks
> > > > > > > > Lyle
> > > > > > > > --- In
> > > > > > > > > --- In
jpro8071
Oiling and cooler (was Bonneville Honda)
Post by jpro8071 »
Unfortunately I'm one of those people that can't remember the different AN fitting sizes, so I'll have to take a closer look at the system to see what size hoses I'm using.
Bill's adapter removes the stock paper filter element. It has an "out" and an "in" fitting.
From the "out" fitting we run a line to an very large external oil filter (the same filter a Ford 302 would run) - and we've got an aftermarket larger capacity (and more efficient) oil filter. A little ways after the filter we have a T fitting. Off of it comes a smaller line that feeds the head, and one that is the same size as the "out" line that goes to the "in" section on Bill's adapter. (When we run a cooler, the cooler goes between the "out" and the oil filter, so that the oil going into the head has been cooled also.)
The smaller line for the head travels maybe 2 or 3 feet to another "T" fitting where we break off two equal size lines to the top of the head. (Remember - we don't have oil flowing up the cylinders to feed the cam/top end and one main bearing via gravity.)
You can see the lines to the top of the head here:
http://images.garagecity.com/49/97/f1_i ... n.orig.jpg
The photo is a little confusing - there are two lines with brass fittings that are the fuel injectors. The two fittings with the blue 90 degree fittings are where the oil get dumped into the top end.
Besides the benefit of cooling the oil, you also add a quart to a quart and a half more capacity, which I think is a plus.
I think next time we'll put some rare-earth magnets inside the oil filter and maybe even epoxied inside the case.
> Thanks
> Craft59@...
> > > Lyle
> > > > --- In
> > > > > Lyle
> > > > > --- In
> > > > > > --- In
> > > > > > > Lyle
> > > > > > > --- In
> > > > > > > > --- In
> > > > > > > > > Thanks
> > > > > > > > > Lyle
> > > > > > > > > --- In
> > > > > > > > > > --- In
Re: Oiling and cooler (was Bonneville Honda)
Eric,
Way over the top, but it looks great.   Are we looking at the engine with the cylinder shrouds removed for maintenance or are you running the car they way?
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > jpro8071 > Sent:
> Saturday, June 19, 2010 10:15
> [2cylinderhondas] Oiling and cooler (was Bonneville
> Honda)
> Unfortunately I'm one of those people that can't remember the different AN > fitting sizes, so I'll have to take a closer look at the system to see what > size hoses I'm using.
> we run a line to an very large external oil filter (the same filter a Ford 302 > would run) - and we've got an aftermarket larger capacity (and more efficient) > oil filter. A little ways after the filter we have a T fitting. Off of it > comes a smaller line that feeds the head, and one that is the same size as the > "out" line that goes to the "in" section on Bill's adapter. (When we run a > cooler, the cooler goes between the "out" and the oil filter, so that the oil > going into the head has been cooled also.) > The smaller line for the > head travels maybe 2 or 3 feet to another "T" fitting where we break off two > equal size lines to the top of the head. (Remember - we don't have oil flowing > up the cylinders to feed the cam/top end and one main bearing via > gravity.) > You can see the lines to the top of the head here:
> The
> photo is a little confusing - there are two lines with brass fittings that are > the fuel injectors. The two fittings with the blue 90 degree fittings are > where the oil get dumped into the top end.
> cooling the oil, you also add a quart to a quart and a half more capacity, > which I think is a plus.
> magnets inside the oil filter and maybe even epoxied inside the > case.
> > I have my oil
> pump out. How about some more detail on the modified oil path from the oil > cooler. The oil cooler to me is the best addition to any air cooled engine. I > am not racing but better oiling is always a good thing.
> > Thanks
> > Craft59@...
> "jpro8071" wrote:
> > > We run Bill's
> oil cooler. Plus the oil to feed the top end (cam) (and one of the mains via > gravity) is fed from a feed off of the oil cooler. So the oil that feeds the > top basically does NOT go up cylinders, which helps to keep it cooler.
> Yes, the crank is a weak point for sure, the new crank should be a good way to > save some engines.
> > > > Lyle
> > > > > And we did
> offset the bore (and re-sleeve) to comfortably get the 700cc size. 750 can be > done, but I'd rather spend the whole week racing than melt down the first day > after spending a year preparing.
> > I've talked more with my sponsor about building cranks. He's gotten a bit > more excited by the idea, which is why I posted the poll on after-market > cranks. (My goal would be to come up with something so I can get my 750cc > motor, and everyone else can get a new crank/piston setup that gets them a > little more displacement and power along with the comfort of knowing it's new > and should last a long time . . . )
> > > > > --- In
> take parts from.
> run.
> movie!
> > > > > > Lyle
> > > > > --- In
> "jpro8071" wrote:
> > > > > > The class is actually limited to 750cc, and since > newer production cars can run EFI, they allow older cars to. (There is a > "classic" production class for larger displacement - carbs or mechanical fuel > injection only.)
> > > > > > > The
> two main parts of the production class is having the "stock" block, and the > body having the stock configuration.
> > > > > > Bonneville is quite an experience. You can really get > up close and "look under the hood" of most of the cars. People are really > friendly, like to answer questions. If anyone out there plans on running a > vehicle, I highly advise attending once to spectate. Get a feel for the > process, environment, rules, etc..
> spectate, let me know. If I'm out there I'm happy to share my pits and perhaps > show you around.
> > > > > > > > Are
> you in a stock under 700cc class? I didn't think you could modify the car that > much without going into the unlimited class.
> > > > Lyle
> > > > > > > > --- In
> "jpro8071" wrote:
> > > > > > > > > You can read more
> here:
> > > > > > > > > --- In
> > > > > > > > > > jpro, your
> Pictures/info.
> > > > > > > > > > Good idea with
> the copper gasket.
> > > > > > > > > > Do you get
> > > > > > > > > > A
> Thanks
> > > > > > > > > > Lyle
> "jpro8071" wrote:
> > > > > > > > > > > I just read my
> post and realized it wasn't that clear - I'm talking about head gaskets made > from one piece of copper with no other gasket material involved.
> > > > --- In
> "jpro8071" wrote:
> > > > > > > > > > > > Since
> no water is involved, all copper head gaskets work great. We've been using > them on the Bonneville Honda for years with great success. PM me if you have > interest in getting one and I'll see what sort of bulk deal I can arrange.
jpro8071
Post by jpro8071 »
In that photo we were not running them - which in hindsight was wrong to do. From my dyno time years prior I learned just how prone to heat soak (and subsequent power loss) these motors are. But since I'm perpetually on information overload I forget these things now and then.
Always run the shrouds, and if you put in an electric fan always have it running - even when the car is moving. The air through the grill might be buffered/blocked by turbulence - the fan is needed to make sure air gets through the cylinders.
(Bill - I know you know all of this and preach it fairly often, but I'm sure there are new readers that haven't gotten these words of wisdom yet.)
, wrote:
> Eric,
> way?
]On Behalf Of jpro8071
> Sent: Saturday, June 19, 2010 10:15 AM
> Subject: [2cylinderhondas] Oiling and cooler (was Bonneville Honda)
> an "in" fitting.
, "lyletrudell"
> > Thanks
> > Lyle
> > Craft59@
> to keep it cooler.
, "lyletrudell"
> the pump?
> > > > Lyle
> > > > --- In
, "jpro8071"
> > > > > --- In
, "lyletrudell"
> to 750.
> > > > > > Lyle
> > > > > > --- In
, "jpro8071"
> injection only.)
> the head gasket.
> around.
> > > > > > > --- In
, "lyletrudell"
> injection.
> > > > > > > > Lyle
> > > > > > > > --- In
, "jpro8071"
> > > > > > > > > --- In
, "lyletrudell"
> > > > > > > > > > Thanks
> > > > > > > > > > Lyle
> > > > > > > > > > --- In
, "jpro8071"
> > > > > > > > > > > --- In
, "jpro8071"
Tran Nguyen
Post by Tran Nguyen »
thats a wild setup! any more pics?
