my first engine problem
Colin
Post by Colin »
Well, I have owned my 600 for almost two weeks now and have put on
about 600 mile, but now I have run into a problem. I noticed that I
heard a intermittent tapping noise from the upper engine. I pulled
off the valve cover and found that the rockers and chain were rubbing
on the underside of the cover. The chain seems to have alot of slop
in it, and I was wondering if there is a tension adjustment, if so,
how and where? Let me know what I should check for, I am kind of
miss'n drive'n it already. Thanks,
Colin
Re: my first engine problem
> Colin
I don,t see how the rockers could hit the v.cover,unless the
removeable "oil separator baffle" came loose on underside of valve
cover,as faras the chain being noticeably loose,don't run it until
you know what,s going on. Sounds like your hydraulic chain adjuster
is frozen and the plunger can't extend in order to maintain correct
tension. Also,could be a bad lower tensioner wheel. Since there is
no adjustment,you'll have to start troubleshooting by removing fan
housing,then taking out the tensioner located near base of cylinder
or bottom of fan housing. The plunger is normally extended by a
spring inside,but sometimes gets siezed in the retracted position,in
this case,you'll need to replace it,and whatever else is bad,like
the chain. If you run it like this YOU WILL JUMP CAM TIMING AND THEN
BEND VALVES! Riceburner006
Colin
Post by Colin »
Thanks for the help guys, let me tell you what I found so far. The
baffle on the underside of the valve cover had been broken free and
welded back into place slightly lower than in should. I had to grind
a shall area off the cover so that the rocher won't hit. I thought
this was my noise, not. I took riceburner's advive ad took out the
tensioner from the rear of the engine, the plunger was good, but the
o-rings were hard as a rock. I clean it all up and put new o-rings,
started it, and the noise was still there. The chain seems to have
nice spring tension, and I assume the the oil pressure part is
working. I don't know what the valve clearance spec is, but I an
currently adjusting (guessing) intake .05 and exhaust.07. I hope I am
close. I also noticed that one of the cam lobes had a slight bit of
abnormal wear on one edge, but I don't thing this is the cause of my
noise. I will let you know what I find. I am letting it cool for the
adjustment, then I will start is to hear the ticking about, ha. I am
running out of options. All of your input is welcome, thanks again,
Colin
Tapping 70 owner.
--- In 2cylinderhondas@y..., "william colford" wrote:
> Hi Colin;
> Rice burner is correct in that your cam chain should not be
loose. If
> the chain is as loose as you say then it is already stretched and
should be
> replaced. Take a flash light and look down into the middle of the
engine.
> The center roller should look smooth on the top sides with a rise
in the
> middle. If you look into the back side you should be able to see
further
> into the engine and may see the lower tensioner wheel riceburner
spoke of
> and tell if it is riding no t he plunger at the back side of the
metal
> holder for the wheel. I am including a picture of where these
items are.
> On the anzhonda600owners group page you can read on how to replace
your cam
> chain with out removing the engine or even the head, the article is
in the
> Files section.
> From: "Colin"
> Sent: Monday, November 25, 2002 9:00 PM
> Subject: [2cylinderhondas] my first engine problem
rubbing
> Colin
> 2cylinderhondas-unsubscribe@y...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
larryn600
Post by larryn600 »
I had a ticking noise going on in my 360 sometime ago now, and found that one pistons rings had broken and taken the top of the piston apart and threw some metal into the head.. just a mater of repalcing the piston and ring and all was fine again and it goes like a dream, an everyday runner averaging 40-45mpg.
Hope maybe this may be some help, but hopefully is is somthing les severe that is causeing the tapping or knocking.
Regards Quentin
> Colin
> Thursday, November 28, 2002 1:37
> [2cylinderhondas] Re: my first
> engine problem
> far. The
> baffle on the underside of the valve cover had been broken free > and > welded back into place slightly lower than in should. I had to grind
> running out of options. All of your input is welcome, thanks > again, > Colin > Tapping 70 owner.
> > Hi
> Colin;
> chain should not be
> loose.   If
> should be
> > replaced.
> engine.
> The center roller should look smooth on the top sides with a rise > in > the > > middle.  If you look into the back side you should be able to > see > further > > into the engine and may see the lower tensioner wheel > riceburner > spoke of > > and tell if it is riding no t he plunger at > the back side of the > metal > > holder for the wheel.  I am > including a picture of where these > items are.
> > On the
> anzhonda600owners group page you can read on how to replace > your > cam > > chain with out removing the engine or even the head, the article > is > in the > > Files section.
> Original Message -----
> > From: "Colin"
> > Well, I have owned my 600 for almost two weeks now and have put > on > > about 600 mile, but now I have run into a problem. I noticed that > I > > heard a intermittent tapping noise from the upper engine. I > pulled > > off the valve cover and found that the rockers and chain were
> rubbing
> alot of slop
> adjustment, if so,
> I am kind of
> Colin
> To
> to:
> Your
> Yahoo! Terms of Service
Colin
Post by Colin »
I would rather not think that I could have a snapped ring. I think I
will run a compression test right now to eliminate the chance of it
being that, what should the compression spec be? I am also going to
run a heavier grade oil. Even after every thing I have done up to
this point, the sound is still there. From listening with a
stethiscope, the noise is from under the valve cover. I tried to take
the oil cap off for a better listen, but I ended up getting a bath.
Colin (learning to type slower)
> Regards Quentin
> From: Colin
> To: 2cylinderhondas@y...
> Sent: Thursday, November 28, 2002 1:37 PM
> Subject: [2cylinderhondas] Re: my first engine problem
The
and
grind
thought
the
the
rings,
have
I am
of
my
the
am
again,
> Colin
> Tapping 70 owner.
> > Hi Colin;
> loose. If
and
> should be
the
> engine.
rise
> in the
see
> further
riceburner
> spoke of
the
> metal
> items are.
replace
> your cam
article is
> in the
> > Files section.
> > From: "Colin"
on
that I
pulled
> rubbing
slop
so,
> > Colin
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
