Hello,I need a set of the gaskets between the tail light assembly and the body on my 1972 Honda 600 Coupe.Is there any place to purchase NOS or reproductions?Thanks,
Chuck (mobile)Pleez x cuze enny tie ping or spelin air ores.
Our 1972 Honda 600 Coupe
Our 1961 Vespa 400
Re: Tail light gasket
Moderator: forumadmin
When I put my tail light assemblies back on next week, I'm planning on copying the original gasket shape and cutting it out of a left over inner tube.
On May 31, 2019, at 1:39 PM, Chuck Dean cadean329@... [2cylinderhondas] wrote:
I did that to sandwich the window in the medal rails of the driver and passenger window. Bicycle inner tube worked well.
Sent from my iPhone
Sent from my iPhone
Attachments :They are form gaskets and 1/2" thick. Also they have slotted to fit taillight lens and reverse lens. It will be a little difficult to duplicate with inner tube rubber.
On Fri, May 31, 2019, 9:56 PM art Remai artremai@... [2cylinderhondas] wrote:
Sent from my iPhone
Re: Tail light gasket [2 Attachments]
Bill Colford's parts for the Honda 600 Coupe and Sedan
[Attachment(s) from Nobutoshi Hayashi included below]
Sent from my iPhone
#ygrps-yiv-1522600867
On Friday, May 31, 2019, 10:10:47 PM EDT, Nobutoshi Hayashi dino246.nobutoshi@... [2cylinderhondas] wrote:
Sent from my iPhone
Hello,Bill told me that he uses 1/4 inch vacuum hose that he splits and puts around the tail light housing. Then he uses car wax to shine it like new.I'll stick with his idea... He's build a lot of these cars.
Our 1961 Vespa 400
Did you try Bill Colford at
Sent from my iPhone
Our 1961 Vespa 400
On May 31, 2019, at 7:16 PM, james brown zulinicomics@... [2cylinderhondas] wrote:
Sent from my iPhone
That is what I used. Cut it a bit longer, mine shrunk about an eight of an inch
Sent from me
Hello,
Chuck (mobile)
Our 1961 Vespa 400
Sent from my iPhone
Hello,
Sent from me
On May 31, 2019, at 7:29 PM, Chuck Dean cadean329@... [2cylinderhondas] wrote:
Hello,
Chuck (mobile)
Our 1961 Vespa 400
Sent from my iPhone
Hello,
Attachments :Take a look here to fine other universal rubber parts from Steel Rubber products inc. some universal rubber parts will work. https://d163axztg8am2h.cloudfront.net/static/doc/13/6b/4ca3aa37ac8ed46402d0934d688b.pdf Bill From: 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com]
Sent: Friday, May 31, 2019 8:10 PM
Subject: Re: [2cylinderhondas] Tail light gasket That is what I used. Cut it a bit longer, mine shrunk about an eight of an inchSent from me
Hello,Bill told me that he uses 1/4 inch vacuum hose that he splits and puts around the tail light housing. Then he uses car wax to shine it like new.I'll stick with his idea... He's build a lot of these cars. Chuck (mobile)Pleez x cuze enny tie ping or spelin air ores. Our 1972 Honda 600 Coupe Our 1961 Vespa 400
On May 31, 2019, at 7:16 PM, james brown zulinicomics@... [2cylinderhondas] wrote: Did you try Bill Colford at Bill Colford's parts for the Honda 600 Coupe and Sedan Bill Colford's parts for the Honda 600 Coupe and Sedan On Friday, May 31, 2019, 10:10:47 PM EDT, Nobutoshi Hayashi dino246.nobutoshi@... [2cylinderhondas] wrote: [Attachment(s) from Nobutoshi Hayashi included below] They are form gaskets and 1/2" thick. Also they have slotted to fit taillight lens and reverse lens. It will be a little difficult to duplicate with inner tube rubber. On Fri, May 31, 2019, 9:56 PM art Remai artremai@... [2cylinderhondas] wrote: I did that to sandwich the window in the medal rails of the driver and passenger window. Bicycle inner tube worked well.Sent from my iPhone
On May 31, 2019, at 6:46 PM, J Graf jgraf@... [2cylinderhondas] wrote: When I put my tail light assemblies back on next week, I'm planning on copying the original gasket shape and cutting it out of a left over inner tube. On May 31, 2019, at 1:39 PM, Chuck Dean cadean329@... [2cylinderhondas] wrote: Hello,I need a set of the gaskets between the tail light assembly and the body on my 1972 Honda 600 Coupe.Is there any place to purchase NOS or reproductions?
Excellent, Bill. Thanks for the link. I downloaded the pdf for reference. I need rear quarter window gaskets for one of my sedans.
