Hello all. Now that I have my brake system up and running….. Noted some blue smoke out the exhaust while driving. Checked compression – approx. 100 psi for both cylinders – should be ~150 psi. Wet compression test changed little – so rings are probably ok. Checked valve clearance – all good. Checked head nut torques – all good. When I rebuilt engine I used a copper head gasket from ‘Honda600carparts’. I just noticed that this gasket needed annealing before install to soften it – I did not do this. Thinking perhaps this is cause for low compression. Does anyone have experience with this copper head gasket ? Thanks. Greg Prentice Toromont Power Systems 905 488 2571
This e-mail and any attachments may be confidential or legally privileged. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited. Please notify us immediately by email at corpmail@... or by telephone (collect if necessary). Please delete this email and destroy any copies. Thank you for your cooperation.
Toromont Industries Ltd., 3131 Highway 7 West, Concord, ON, L4K 1B7 www.toromont.com (416)667-5511.
Ce courriel, ainsi que tous les fichiers joints, sont consid r s comme confidentiels ou juridiquement privil gi s. Si vous n' tes pas le destinataire d sign du pr sent message, soyez avis que toute divulgation, copie, distribution ou action se fondant sur le contenu est strictement interdite. Veuillez nous en aviser imm diatement par courriel l'adresse corpmail@... ou par t l phone ( frais vir s si n cessaire). Veuillez effacer ce courriel et toute copie ventuelle. Merci pour votre coop ration.
Re: N600 sedan - compression
Moderator: forumadmin
Greg, New copper head gaskets used in the motorcycle industry typically do not need to be annealed unless you are reusing it. (the advantage of solid copper gaskets). Your blue smoke may be worn valve guides, a common issue. Most notable after engine deceleration and then acceleration. During the deceleration, manifold vacuum pulls oil through the intake valve guides, thus the smoke. Newer cars and motorcycles have valve guide seals, Honda 600s don t. Your low compression for a rebuilt engine is something to address. Hope this is helpful. From: Greg Prentice GPrentice@... [anzhonda600owners] Sent: Saturday, August 18, 2018 9:22 PM To: anzhonda600owners@yahoogroups.com Subject: [anzhonda600owners] N600 sedan - compression
Hello all. Now that I have my brake system up and running .. Noted some blue smoke out the exhaust while driving. Checked compression approx. 100 psi for both cylinders should be ~150 psi. Wet compression test changed little so rings are probably ok. Checked valve clearance all good. Checked head nut torques all good. When I rebuilt engine I used a copper head gasket from Honda600carparts . I just noticed that this gasket needed annealing before install to soften it I did not do this. Thinking perhaps this is cause for low compression. Does anyone have experience with this copper head gasket ? Thanks. Greg Prentice Toromont Power Systems 905 488 2571
Virus-free. www.avast.com
Attachments : Going to a thicker oil has reduced the blue smoke… I will just drive it – not had at highway speed yet…. Maybe will do leak down test….. From: anzhonda600owners@yahoogroups.com [mailto:anzhonda600owners@yahoogroups.com]
Sent: Saturday, August 18, 2018 9:49 PM
Subject: [anzhonda600owners] Re: N600 sedan - compression Is power ok? Maybe just drive it and ignore the blue cloud following you. Dad From: anzhonda600owners@yahoogroups.com on behalf of Greg Prentice GPrentice@... [anzhonda600owners]
Sent: August 18, 2018 9:22:16 PM
Subject: [anzhonda600owners] N600 sedan - compression Hello all. Now that I have my brake system up and running…... Noted some blue smoke out the exhaust while driving. Checked compression – approx. 100 psi for both cylinders – should be ~150 psi. Wet compression test changed little – so rings are probably ok. Checked valve clearance – all good. Checked head nut torques – all good. When I rebuilt engine I used a copper head gasket from ‘Honda600carparts’. I just noticed that this gasket needed annealing before install to soften it – I did not do this. Thinking perhaps this is cause for low compression.. Does anyone have experience with this copper head gasket ? Thanks. Greg Prentice Toromont Power Systems 905 488 2571 This e-mail and any attachments may be confidential or legally privileged. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited. Please notify us immediately by email at corpmail@... or by telephone (collect if necessary). Please delete this email and destroy any copies. Thank you for your cooperation.
Toromont Industries Ltd., 3131 Highway 7 West, Concord, ON, L4K 1B7 www.toromont.com (416)667-5511. Ce courriel, ainsi que tous les fichiers joints, sont consid?r?s comme confidentiels ou juridiquement privil?gi?s. Si vous n'?tes pas le destinataire d?sign? du pr?sent message, soyez avis? que toute divulgation, copie, distribution ou action se fondant sur le contenu est strictement interdite.. Veuillez nous en aviser imm?diatement par courriel ? l'adresse corpmail@... ou par t?l?phone (? frais vir?s si n?cessaire). Veuillez effacer ce courriel et toute copie ?ventuelle. Merci pour votre coop?ration.
Typically copper head gaskets are for racing where the head gets removed frequently. I definately wouldn't use one on a daily driver
because the amount of oil leaks we have with just the stock gaskets. I always apply Honda Bond or Three Bond when I assemble an engine
and don't think the copper would benefit from that.
What rings did you install? and if they were from the same source were they installed correctly? I just got a supply of Hastings
rings and even though they are in separate pouches they don't say which way is up. Then did you install the ring gaps in thirds? I know
they don't stay that way, they walk around, but you have to start somewhere.
I would suggest a leak down test. That is a reversed compression
test where you pump air through the spark plug hole and listen where it seeps out. I made my own leakdown tester with an air regulator and the hose from
a compression tester. Then rotate engine to TDC where valves are closed and block the crank so it cant turn - easy to do with a 17 or 22 mm wrench braced against cross bar. Remove oil cap and air filter for easier listening. Apply about 20 PSI and see what happens.
Well I get blue smoke after I rebuilt my N600 and Z600 from time to time .I may have to use a better set of rings Chrome Coated rings ? is what people are telling me I might be saying that wrong
Sent from my iPad
Sent from my iPad
On Aug 18, 2018, at 6:22 PM, Greg Prentice GPrentice@... [anzhonda600owners] wrote:
Power is good
Sent from my iPad
Hello all. Now that I have my brake system up and running ... Noted some blue smoke out the exhaust while driving. Checked compression approx. 100 psi for both cylinders should be ~150 psi. Wet compression test changed little so rings are probably ok. Checked valve clearance all good. Checked head nut torques all good. When I rebuilt engine I used a copper head gasket from Honda600carparts . I just noticed that this gasket needed annealing before install to soften it I did not do this. Thinking perhaps this is cause for low compression.. Does anyone have experience with this copper head gasket ? Thanks. Greg Prentice Toromont Power Systems 905 488 2571
Sent from my iPad
On Aug 18, 2018, at 6:48 PM, Robert Prentice rp13@... [anzhonda600owners] wrote:
