Hi guys, I've been having some strange issues on my recently purchased AN600. All the lights work if I turn on the headlights, but when I turn on the hazards everything except the front right signal flashes. If I have the hazards on, and move the turn signal down to indicate left, then only the left lights flash. If I indicate right, then the hazards act normally with exception of the front right. but without the hazards on the turn signals do nothing. I've replaced the turn signal switch on the steering column and all of the bulbs (a couple times) but that wasn't it. Any help would be greatly appreciated! Thank you!
-Kelby
AN600 turn signal issues
Moderator: forumadmin
