Attachments : If the correct adjustment for the release bearing to the clutch is stated in attachment c-ch31 (Honda 600 shop manual Coupe supplement) the part is identified in the parts manual attachments cpar-18 (#19) and listed on cpar-19. If the bearing has been touching the clutch diaphragm spring cpar-18 (#7) then it may be warn out and could need replacement. But making the correct adjustment may fix the problem. Bill
From: 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com]
Sent: Tuesday, April 21, 2015 4:27 AM
Subject: [2cylinderhondas] rotating release bearing shaft
Hi every one. Today i was tunig up my honda n600 and i noticed that my release bearing shaft was rotating. It makes a squeeky sound when it touches the release lever. Is that suppose to happen? I thought it was a bit strange.
I adjusted the lever looser so it wont touch it when the clutch isnt used but that cant be right.
Thanks
Moderator: forumadmin
