Re: Honda N600 front strut seals
Moderator: forumadmin
wondering if anyone knows where to acquire new SEALS for FRONT STRUTS for AN600 Sedan any leads gladly appreciated i have to rebuild mine. thanks in advance
I believe others have had success stacking seals or using a spacer. One of the seals is an unusual size due to its height. I ended up finding seals that I believe are the right size from a company called Kastas. (search kastas seals) Of course they are not in the US and have no distributors here so I did have to wait a while. I have built one set of struts with them and it went well. Here are the part numbers if you want to try and get them...Tall seal: Code K21-022/7 PU Size:22X34X10 Material: PU9201Short seal: Code K21-022/11 PU Size: 22X30X5 Material: PU9201
