Is my engine original?
Hi everyone,
My Honda Z Coupe's engine number starts with AN600. Does this mean my engine is not the original for this car?
Chuck (mobile)
Re: Is my engine original? [2 Attachments]
Moderator: forumadmin
If your engine number starts with N600-E25- - - - - Then it is a Z 600 motor. From: 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com]
Sent: Tuesday, September 20, 2016 12:36 PM
To: Honda 600 Group
Subject: [2cylinderhondas] Is my engine original?
Hi everyone,
Chuck (mobile)
To: Honda 600 Group
Hi everyone,
Chuck (mobile)
Cool Beans! Thanks for the info. I was a little worried that my "all original, numbers matching, survivor "was not quite what I thought it was.
Chuck (mobile)Pleez x cuze enny tie ping or spelin air ores.
If your engine number starts with N600-E25- - - - - Then it is a Z 600 motor. From: 2cylinderhondas@yahoogroups.com [2cylinderhondas@yahoogroups.com]
To: Honda 600 Group
Hi everyone,
Chuck (mobile)
To: Honda 600 Group
Hi everyone,
Chuck (mobile)
So, is an "N" 600 engine different from a "Z"? All these years I thought all running gear was the same, with a different body.
Sent: Tuesday, September 20, 2016 4:57 PM
Subject: RE: [2cylinderhondas] Is my engine original?
To: Honda 600 Group
Subject: [2cylinderhondas] Is my engine original? Is my engine original?
Hi everyone,
Chuck (mobile)
Pleez x cuze enny tie ping or spelin air ores. #ygrps-yiv-1930617892
The engine numbers start with the first two numbers being different; N600 E10- - - - - is an early Sedan engine number with a constant transmission. N600 E15- - - - - is a later (after 1 April 1971) Sedan engine number with a full synchro transmission. N600 E20- - - - - is an engine number for some Z or Coupe models sold in Europe with a constant transmission. N600 E25- - - - - is for the Z or Coupe with a full synchro transmission. N600 E50- - - - - is to a Sedan having an Automatic transmission. The internal part for the cases of the constant and full synchro transmissions is different. The engine for the Z or Coupe have different parts from the Sedan and looking at the two; Sedan and Coupe parts manuals will show this. The full synchro transmission started in 1 April 1971, at the same time as the Z or Coupe production. Many parts are the same, however many are not. All sedan chasses numbers are sequential the engine numbers don’t follow as they are made for different locations and markets, as are the Z or Coupe chassis numbers. This is why knowing your chassis, engine and date of manufacture are important when looking for parts using the factory parts manual. Bill From: 2cylinderhondas@yahoogroups.com [mailto: 2cylinderhondas@yahoogroups.com ]
Sent: Tuesday, September 20, 2016 7:58 PM
Subject: Re: [2cylinderhondas] Is my engine original? So, is an "N" 600 engine different from a "Z"? All these years I thought all running gear was the same, with a different body.
From: "'Bill' billmyong@... [2cylinderhondas]" < 2cylinderhondas@yahoogroups.com >
Subject: RE: [2cylinderhondas] Is my engine original? If your engine number starts with N600-E25- - - - - Then it is a Z 600 motor. From: 2cylinderhondas@yahoogroups.com [mailto: 2cylinderhondas@yahoogroups.com ]
To: Honda 600 Group
Hi everyone,
Chuck (mobile)
Attachments : Did you actually see the number on your engine or just look at the VIN tag? Usually the actual # is covered by dirt & sludge, it's located on the left side of the engine between clutch arm & cooling fan. In the USA it's like Bill said: N600E- 10xxxxx sedan non synchro N600E-15xxxxx sedan synchro N600E-25xxxxx coupe. In the USA all coupes are synchro Miles
I got my number off the engine itself. My car is missing the Vin tag.pAnd yes, it was covered by a lot of dirt and sludge.
On Sep 21, 2016, at 1:56 AM, 'Miles Chappell #10321' z600miles@... [2cylinderhondas] wrote:
