n.o.s. oversize pistons availability
paul_lee_94112
Presently my engine is apart at the machine shop for rebuilding. Before honing or removing material from the cylinders, they need a set of n.o.s. oversized pistons. Does anybody know of a parts source? or would used oversized pistons be acceptable?
Re: n.o.s. oversize pistons availability
Is it an N600? Some parts 0.25mm o/size here. Used are ok if ok.
https://www.cmsnl.com/honda-n600-sedan- ... ml#results
paul_lee_94112
Wow! Thanks for the tip! I'm building a 1971 Honda N600. Hopefully the machine shop won't require too much in parts($$$). I had owned two Honda sedans (1971 & 1972 ) in the mid 70s. + decided to move on to other cars because parts were getting hard to find by 1979....little did know that I would find one 2 years ago!
