1) if the clutch bearing is not pressed on to the shaft (item #16 in the attachment pictures) fully, it will not have the correct gap to the diaphragm and the adjustment bolt may not be able to compensate properly.
2) if you are not using a genuine Honda part, the aftermarket part being used may be wider/deeper which causes it to be too close to the diaphragm. Again, the adjustment bolt may not be able to compensate properly.
3) is the shaft which the throwout bearing is pressed a genuine Honda part? If not, it may be too long.
4) is the diaphragm plate a genuine Honda part? If not, the height may be greater than the stock part.
And if you ask "what is the correct gap?", my answer would be a gap which is enough so the throwout bearing is not touching the diaphragm plate when the clutch pedal is out. 1 to 2mm is all it takes.
And this is the gap between the bearing and the plate. Enough gap so it is not in constant contact.
> If the correct
> adjustment for the release bearing to the clutch is stated in attachment > c-ch31 (Honda 600 shop manual Coupe supplement) the part is identified in the > parts manual attachments cpar-18 (#19) and listed on cpar-19.
> If the bearing has
> been touching the clutch diaphragm spring cpar-18 (#7) then it may be warn out > and could need replacement.
> But making the correct
> adjustment may fix the problem.
> [mailto:2cylinderhondas@yahoogroups.com]
> Tuesday, April 21,
> 2015 4:27 AM
> [2cylinderhondas] rotating release bearing shaft
> Hi every one. Today i was tunig up my honda n600 and i noticed that my > release bearing shaft was rotating. It makes a squeeky sound when it touches > the release lever. Is that suppose to happen? I thought it was a bit > strange.
> I adjusted the lever looser so it wont touch it when the clutch > isnt used but that cant be right.
> Thanks
