Hi every one. Today i was tunig up my honda n600 and i noticed that my release bearing shaft was rotating. It makes a squeeky sound when it touches the release lever. Is that suppose to happen? I thought it was a bit strange.
I adjusted the lever looser so it wont touch it when the clutch isnt used but that cant be right.
rotating release bearing shaft
PETER WATKINS
Re: rotating release bearing shaft
Doesnt that mean the release bearing has seized up, rusty or just lack of grease and worn out ? not good.
Message Received: Apr 21 2015, 12:26 PM
Cc:
Subject: [2cylinderhondas] rotating release bearing shaft
Cc:
Charles Gould
I am not sure about this particular engine but many engines are designed for this to occur to prevent uneven wear on the shaft. It may not be a problem at all.
Chas Sent from my iPhone
On Apr 21, 2015, at 7:26 AM, "
rickvanderkeur@...
If the correct adjustment for the release bearing to the clutch is stated in attachment c-ch31 (Honda 600 shop manual Coupe supplement) the part is identified in the parts manual attachments cpar-18 (#19) and listed on cpar-19.
If the bearing has been touching the clutch diaphragm spring cpar-18 (#7) then it may be warn out and could need replacement.
But making the correct adjustment may fix the problem.
rickvanderkeur
Thanks all for answering. Today I finally had the time to check it out.
The bearing was seized up. The grease inside dried up. So i cleaned it up and put some new grease in it.
Now it's working as is should work.
